1994 Toyota Corolla Stumbles When Warm
CARMIEVG
Hi. New to your forum, but what I've seen of it, it looks like a good place for competent answers.
OK.. My daughter has a '94 Toyota Corolla, 1.6 liter, with 126621 miles on it. She left it home from school the other day so I could check it over. She told me it had been stalling out on her. I thought spark plugs, wires, etc,.. But when I took it for a test drive to replicate the situation, it was working great.. until it hit operating temperature. Then it started to stumble, hesitate, and almost stall, usually at dile and during acceleration. Apparently it has stalled on her several times. Everything 'looks' in order, and the "check engine" light is not on. I tried accessing the codes by jumping Te1 and E1 with a paper clip, and all I got was a constant blinking light.. No codes, just a steady blink - blink - blink - blink... She just got home from school and told me that in the traffic jam trying to leave the parking lot it did stall on her a few times.
I really need to fix this. Any ideas?
Thanks,
Chris.
Sep 21, 2007 at 9:28 AM
  • 55,845 POSTS
Two things come to mind, fuel pump, or ignition system, if either of these components fail the computer might miss it and say everthing is ok. Check the fuel pump and ignition module, we have repalced both on that car. If it dies only at idle, try checking for broken or cracked vacuum lines, inspect the air intake boot to the air filter, this can no tears in it,l next try servicing the throttle bore and IAC motor https://www.2carpros.com/how_to/how_to_tune_up.htm , if this dosnt help try replacing the idle air control motor. please let me know, thanks for visiting 2carpros.com
Sep 21, 2007 at 9:49 AM
CARMIEVG
I appreciate the rapid response!!! But looking at your answer, I'm inclined to lean more towards the ignition aspect rather than the fuel pump. I can't imagine the fuel pump only malfunctioning at slower speeds; wouldn't such a thing be more likley to manifest itself at higher RPMs? And since it runs just fine when cold, which vacuum lines would be most likely be the culprits? As for the air intake boot, do you mean before the filter? Or do you mean the cover over the air filter and plastic tube which runs between the filter and the throttle body? The latter appears to be fully intact. And by "servicing", do you mean dismantle and clean? Or replace?
Thanks,
Chris.
Sep 21, 2007 at 12:34 PM
  • 55,845 POSTS
yes, it does sound like ignition system, try a new set of plug wires and plugs, cap and rotor. On the air intake tube, check between the throttle body and the mass air flow sensor.
Sep 25, 2007 at 3:46 AM
CARMIEVG
I talked with a neighbor, who is an instructor at the local Tech College in the diesel mechanics program, where the entire automotive/mechanical section is one big happy family, and he suggested something along the lines of the Mass Airflow System as well. I had expended about a half can of intake cleaner into the thing, but it made no difference. He also suggested I take it to a shop with the right equipment to properly diagnose the issue. :( No sense in throwing parts at the car in a hit-or-miss attempt at repairs... On the bright side, he recommended a shop about two miles away, where the owner is a former student of his. They connected their machine to it, ran it till warm, and diagnosed the Air Flow Metering system as the culprit. They then "fogged" the intake, cleaning the top end of the engine, including the intake, throttle body, and cylinder heads. $300 later it runs like a champ. My daughter is tickled pink at the newfound "power" her Corolla 1.6 has, and I'm sure she will also see gains in fuel effiiciency. He also suggested new cap, wires, plugs, etc,.. That's what Saturdays are made for. ;)
Again, I thank you for your input, and rest assured I will be looking to this forum again if the need arises.
Chris.
Sep 28, 2007 at 8:00 AM
Suggested Repair
The warm stumble was traced to the airflow metering system. Cleaning the intake, throttle body, and related top-end passages resolved it. Also inspect the intake tube between the throttle body and mass airflow sensor, and service the plugs, wires, cap, and rotor.
Conversation Summary
A 1994 Toyota Corolla 1.6 with about 126,000 miles ran well when cold but stumbled, hesitated, and sometimes stalled once warm, especially at idle and during acceleration. No check-engine light or stored codes appeared. An expert suggested checking the fuel pump, ignition system, vacuum lines, intake boot, throttle bore, and idle air control motor, then recommended plugs, wires, cap, and rotor plus inspection between the throttle body and mass airflow sensor. A shop diagnosed the airflow metering system, cleaned the intake and top end, and the car then ran normally. Ignition parts were still recommended for later service.
