The engine idles fine but stumbles when I try to accelerate. This only happens after the engine is warmed up, and in the >2K RPM range. Once I accelerate past 2.5K RPM or shift past 2nd gear, it is fine. There are no engines code, no obvious vacume leaks (though I've not tested with gage). Recently replaced the following: timining belt, spark plugs and wires, distubtor and rotor, PCV, water pump, belts, and vavle cover gasket. Any comments, suggestion are greatly appreciated!
SPONSORED LINKS
Thursday, December 10th, 2009 AT 3:01 PM
