Hope that someone will respond. My car recently had a leak on the cylinder head (water flooded the no.1 piston) and it had to have the gasket replaced. When the engine is cold, it will start - the choke will kick in. However after a few minutes it will start to idle rough and stalls if foot is taken off the accelerator. Then it will refuse to start (sounding as if the battery is dead). Both my starter and battery are new (less than 3 mths old).
Any idea what the problem could be?
SPONSORED LINKS
Wednesday, October 31st, 2007 AT 5:43 AM
