1998 Toyota Corolla Sputtering and Stalling
MARIEK
  • 8 POSTS
1998 Corolla VE manual transmission with 165,000 miles. Had major tune-up (fuel filter, spark plugs, air filter, wires, power steering fluid, pressure p/s hose)exactly one month ago because the engine was "running rough" according to the mechanic. Ran fine for 3 days, then would not turn over. Got about half mile down the road and battery died completely. Replaced battery.
For the last week, car has sputtered at take off, with puttering sound coming from exhaust pipe. Today, during a 80 mile drive, car stopped accelerating at 65mph no matter how much gas I gave it. Then would suddenly accelerate again, until I let my foot off the gas for a second then back to hesitating and sputtering. Cycle continued until I had to stop.
When I stopped, car stalled. Cranks strong, but would not turn over unless I gave it a lot of gas. When I took my foot off the accelerator, tried to stall until I depressed accelerator again.
Got home and turned off car, tried to restart. Started up with some difficulty (lots of sputtering and hopping/shaking). In general, not running well.
Car tends to burn oil during long drives. I have to top it off once every week (or more if I drive a lot that week). Mechanic claims this is not a problem. Use 20w/50 at his suggestion. Topped it off today.
I want to take it back to the mechanic, but I need to have some idea of what the problem is because between a new battery and the tune-up, I've spent $700. I love my car and I'm not ready to give her up. Is this something that can be repaired or is it just time to upgrade?
May 31, 2007 at 10:07 AM
2CARPRO JACK
  • 11,533 POSTS
Have the PCM scanned for codes. This will give us a place to start. If it is burning alot of oil, then it may have some bigger problems than just electronics
Jun 1, 2007 at 12:44 AM
MARIEK
  • 8 POSTS
Thanks so much for your reply.
I just had it checked for codes yesterday after someone suggested I may have a "vapor lock" and to use STP Gas Treatment (didn't do that). The codes came up as misfires on 2 spark plugs (2 and 3).
I ordered a new coil pack, but can't have it installed until Monday. I was told it was okay to drive a couple of miles as long as I put it in neutral when stopped and to keep giving it a little gas. True?
When I got my tune-up, I recall the mechanic mentioning that I would need a new coil , but he said not to feel like I had to hurry. That was a month ago. Am I on the right track now?
Jun 2, 2007 at 4:08 PM
2CARPRO JACK
  • 11,533 POSTS
The oil burning is what concerns me. Have your mechanic do a compression test before installing any parts. Since the misses are on cylinders next to each other, we need to be sure it isnt a head gasket blown between the two.Other than that, sounds like it may be the problem
Jun 3, 2007 at 12:27 AM
MARIEK
  • 8 POSTS
This is tough because you are being so incredibly helpful and I'm trying to follow your advice, but...parts stores? Grrr.
I've made an appointment for the compression test as you advised. However, I had to replace the coil since the parts store wouldn't take it back! Just as you said, it didn't fix the problem at all. So, I'm up to $850 spent and a car still broken in the exact same way.
Thanks for your help so far!
Jun 4, 2007 at 3:44 PM
2CARPRO JACK
  • 11,533 POSTS
Get back to me with the results of the comp test.
Jun 5, 2007 at 12:56 AM
MARIEK
  • 8 POSTS
I don't know why I'm excited about this, Jack, but you were right! Had the compression test today and it's a blown head gasket between 2 and 3 causing the misfire! He quoted me a price range from $800-$1800 for repair, so...
...I test drove cars today; buying tomorrow.
You have been very helpful to me. I just wish I'd found you sooner. Thanks for all the advice.
Jun 5, 2007 at 12:52 PM
2CARPRO JACK
  • 11,533 POSTS
Glad to be of help.
Jun 6, 2007 at 12:45 AM
Suggested Repair
Scan for codes and perform a compression test before replacing ignition parts. Adjacent misfires on cylinders 2 and 3 were confirmed as a blown head gasket; repair the head gasket or weigh the quoted repair cost against replacing the vehicle.
Conversation Summary
A 1998 Toyota Corolla with 165,000 miles sputtered, hesitated, stalled, and burned oil after a recent tune-up and battery replacement. Codes showed misfires on cylinders 2 and 3. A coil pack did not fix it. The expert recommended a compression test before more parts because adjacent misfires can indicate a blown head gasket. Testing confirmed a blown head gasket between cylinders 2 and 3, with a repair quote of $800 to $1,800. The owner decided to replace the car.
