1988 Toyota Corolla SPUTTERS
MADAHAM
  • 1988 TOYOTA COROLLA
  • 4 CYL
  • FWD
  • 196,000 MILES
Hi my 1988 toyota corolla sputters when I put it in gear and put a load on the engine. It idles just fine but when I accelerate or go up a hill it loses power. I changed the spark plugs and airfilter and it runs a lot better but still has a bit of a miss when I put it under a load.
Monday, February 15th, 2010 AT 2:23 PM
Hi MADAHAM, Welcome to 2carpros and TY for the donation
Check the fuel pressure if its within specs-if okay check and test for an excessive backpressure in the exhaust system-could be a partially clogged catalytic converter also the following-airflow meter and throttle position sensor-
Monday, February 15th, 2010 AT 4:41 PM
