1996 Toyota Corolla can't pick up speed
HACKERID
  • 1996 TOYOTA COROLLA
Transmission problem
1996 Toyota Corolla 4 cyl Two Wheel Drive Automatic
the engine can't pick up speed while using a/c. After a stop it take a little while to gain speed but when not using a/c it alright
Saturday, August 22nd, 2009 AT 10:11 AM
MMPRINCE4000
  • 8,548 POSTS
When AC is commanded the idle speed should increase and air and fuel flow.
If not then have the Idle Air Control valve checked.
But the car will not have as much power as it does with AC off, the compressor takes engine power to run it, this is especially true the older the car is.
Sunday, August 23rd, 2009 AT 8:39 AM
