There should be a diagnostic port in the engine compartment. You need to remove all computer advance to set base timing.
Normally this is connector TE1 and E1, short them, start car and set base timing to 10degrees BTDC.
SInce this is an OBDII car, there should be a sticker on hood or front of car that describes procedure.
SPONSORED LINKS
Sunday, May 3rd, 2009 AT 7:02 AM
