air conditioner works while driving but blows warm air when coming to a stop or sitting at idol after driving
Aug 17, 2010 at 5:20 AM
WRENCHTECH
✓Experienced Mechanic
Is the cooling fan running at full speed whenever the A/C is on?
Do you have a set of professional gauges for further testing?
Aug 17, 2010 at 5:31 AM
ROBERTMCONNOR
MEMBER
[quote:cfa04f3008="Wrenchtech"]Is the cooling fan running at full speed whenever the A/C is on?
Do you have a set of professional gauges for further testing?[/quote:cfa04f3008]
yes and yes gauge reads at 50 psi with ambiant temp at 95 degrees
Aug 17, 2010 at 5:57 AM
WRENCHTECH
Ambient? You mean with engine off? That would be way too low and probably out of refrigerant. If that is a running pressure, what was the high read at that time?
Aug 17, 2010 at 7:17 AM
ROBERTMCONNOR
MEMBER
[quote:8576175327="Wrenchtech"]Ambient? You mean with engine off? That would be way too low and probably out of refrigerant. If that is a running pressure, what was the high read at that time?[/quote:8576175327]
idk but have always checked it while running and never over 50 psi
Aug 17, 2010 at 8:44 AM
WRENCHTECH
Yes, it was the term "ambient" that threw mean off. That means static or room temp. What is the high side at this time?
Aug 17, 2010 at 9:20 AM
ROBERTMCONNOR
MEMBER
[quote:4878317163="Wrenchtech"]Yes, it was the term "ambient" that threw mean off. That means static or room temp. What is the high side at this time?[/quote:4878317163]
I dont know my number is 3347071682
Aug 17, 2010 at 9:31 AM
WRENCHTECH
We don't make phone calls. You stated you had a set of professional gauges. Do you know how to use them?
