HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Drivetrain
Transfer Case
SPONSORED LINKS
1996 Toyota Corolla
TIKKI SWEETS
MEMBER
1996 TOYOTA COROLLA
Suspension problem
1996 Toyota Corolla 4 cyl Front Wheel Drive Automatic
When I put in a left lock I am getting a cruk cruk sound on the right hand side
Friday, January 2nd, 2009 AT 9:48 AM
TIKKI SWEETS
MEMBER
SPONSORED LINKS
Friday, January 2nd, 2009 AT 9:56 AM
MMPRINCE4000
MECHANIC
Inspect your CV axle boots for tears/rips/grease leaking. If torn they will need to be replaced.
Saturday, January 3rd, 2009 AT 8:54 AM
Please
login
or
register
to post a reply.
Related Transfer Case Content
1996 Toyota Corolla 1996 Toyota Corolla Stops...
Transmission Problem 1996 Toyota Corolla 4 Cyl Two Wheel Drive Automatic Hi, I Have 1996 Toyota Corolla. It Suddenly Stops When I...
Asked by
samir_1976
1996
TOYOTA COROLLA
GUIDE
Transfer Case Replacement
An automotive transfer case is designed to distribute engine horsepower to the front and rear wheels equally by using two driveshafts and is usually bolted to the rear of...
1996 Toyota Corolla Can't Pick Up Speed
Transmission Problem 1996 Toyota Corolla 4 Cyl Two Wheel Drive Automatic The Engine Can't Pick Up Speed While Using A/c. After A Stop...
Asked by
hackerid
1 ANSWER
1996
TOYOTA COROLLA
1996 Toyota Corolla
Engine Mechanical Problem 1996 Toyota Corolla 4 Cyl Four Wheel Drive Automatic How Can I Time The Car?
Asked by
Rayan
1 ANSWER
1996
TOYOTA COROLLA
2007 Toyota Corolla Idle Prm Question
Engine Performance Problem 2007 Toyota Corolla 4 Cyl Front Wheel Drive Manual 52k Miles My 2007 Corolla S Always Idles At About 1100...
Asked by
corollaguy10
2007
TOYOTA COROLLA
2005 Toyota Corolla
2005 Toyota Corolla 4 Cyl Front Wheel Drive 75000
Asked by
robertmconnor
2005
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Driveshaft Removal
How to Replace Wheel Hub Assembly
Transmission Problem Repair - Automatic
Online car repair manuals
