1994 Toyota Corolla Oil leak
KNOLEGE
  • 1994 TOYOTA COROLLA
  • 4 CYL
  • 217,278 MILES
What could be the cause of the oil leaking
Tuesday, July 27th, 2010 AT 12:07 AM
  • 31,937 POSTS
Hi there,
can you give me any indication as to roughly where on the engine or the transmission the oil leak may be and is it black or red oil leaking?
Mark (mhpautos)
Tuesday, July 27th, 2010 AT 12:28 AM
KNOLEGE
It leaks from the passenger side, out the bottom of the car.
And it leaks when the car is not running. The oil was a light brown color.
Tuesday, July 27th, 2010 AT 1:34 AM
  • 31,937 POSTS
Hi there,
Could be a front crank shaft oil seal r the oil pump, check the front of the engine and look at the top around the rocker cover as well, look for the highest point that you can see oil, you may need to wash the engine down and check after a short run for fresh leaks.
Mark (mhpautos)
Tuesday, July 27th, 2010 AT 5:26 AM
KNOLEGE
Thanks for your help and support
Wednesday, July 28th, 2010 AT 1:13 AM
