1994 Toyota Corolla OIL LEAK
CATHYSHELLEY4444
  • 1994 TOYOTA COROLLA
  • 4 CYL
  • 32,000 MILES
ALL OF A SUDDEN THE OIL IS LEAKING FROM MY CAR. ESPECIALLY WHEN IT IS PARKED? WHY IS THIS?
Tuesday, November 4th, 2008 AT 3:13 PM
  • 31,937 POSTS
Hi there,
You will have to wash the engine down and run and check for fresh leaks, check the oil filter is tight, the oil pressure switch is not leaking, sump plug is tight and look for any leaks from the front or rear of the motor as there are seals here that can cause problems, start here.
Mark (mhpautos)
Tuesday, November 4th, 2008 AT 5:15 PM
