1999 Toyota Corolla ENGINE OIL LEAKAGE
GOWTHEY
  • 1999 TOYOTA COROLLA
Engine Mechanical problem
1999 Toyota Corolla 4 cyl Two Wheel Drive Manual 196K miles
HELLO,
MY QUESTION IS MY ENGINE OIL IS LEAKING BADLY AND I AM NOT ABLE TO FIND THE LEAKGE COZ IT DOES NOT LEAVE ANY STAINS IN THE PARKING AREA, BUT IT IS LEAKING A LOT. RECENTLY I CHANGED AN ALUMINIUM PIPE NEAR ENGINE OIL TANK. PLEASE HELP ME AND SUGGEST ME
Friday, March 12th, 2010 AT 11:46 PM
SERVICE WRITER
  • 9,123 POSTS
There are no signs of external leakage?
You have looked thoroughly?
I would suggest to check to make sure there is good vacuum at the pcv valve. IF not, fix the pcv system to restore the vacuum.
IF it is good, then pull the spark plugs and look at there condition for signs of burning.
Saturday, March 13th, 2010 AT 5:37 AM
GOWTHEY
Hai, previously I asked a question regarding my oil leakage. When I told a mechanic about my car problem he said that my engine is burning my oil and I had to replace my engine. Is there any solution other than replacing. And I also see black smoke coming out at the back.
Saturday, March 20th, 2010 AT 2:11 PM
MMPRINCE4000
  • 8,548 POSTS
Perform a compression test to see if rings are bad, next a leak down test to check the seals.
You can replace the engine with a used one, it will be considerably cheaper.
If rings are bad, then possible oil pump, or it was ran low on oil.
Sunday, March 21st, 2010 AT 7:35 AM
