1998 Toyota Corolla Front Wheel Drive Manual
Hi, I seek your advice to solve my engine oil leak. Mine is a Toyota Corolla 1998. Engine Oil is leaking leaving traces at chain cover, tappet cover, and from a few more places. I have tried changing sealing for tappet cover and crank cover but to no avail. I have this strong feeling that the crank breather pressure has increased abnormally due to which oil keeps leaking out.
Please note that the oil does not leak when the engine is off. Only when the car drives, the engine oil leaks extensively, so much that the oil level comes down to about 60% every second day. I am sort of sure after reading the forums that its the crank pressure. What could be the causes of it and how to solve Kindly advise. Really appreciate you help.
Speed.
SPONSORED LINKS
Monday, June 16th, 2008 AT 11:16 PM
