HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Corolla
Engine
Symptoms
Oil Leak
SPONSORED LINKS
1997 Toyota Corolla Oil leaks
KALLIEC
MEMBER
1997 TOYOTA COROLLA
4 CYL
FWD
MANUAL
330,000 MILES
Oil leaks. Needs to top-up power steering fluid every second day.
Is home replacement of seals/gaskets possible?
Regards.
Kallie.
Tuesday, August 24th, 2010 AT 11:33 AM
MECHANIC
Hi there,
Often this is not the case as special tooling is required.
Mark (mhpautos)
SPONSORED LINKS
Wednesday, August 25th, 2010 AT 5:04 AM
MMPRINCE4000
MECHANIC
Check if it is leaking from pump or from pressure/return lines.
As Mark said, rebuilding PS pump is not s DIY job, but hose replacement is.
Wednesday, August 25th, 2010 AT 8:06 AM
Please
login
or
register
to post a reply.
Related Engine Oil Leak Content
Oil Leak
Hi, I've Got A Toyota Tazz, 1300 '97 Model. I Recently Changed Gearbox Seal And Cv Seal But I Still Have An Oil Leak My Mechanic Said It...
Asked by
irshaadr
1 ANSWER
1997
TOYOTA COROLLA
GUIDE
Engine Oil Leak
A car engine uses motor oil to lubricate the internal moving parts of the engine such as crankshaft, rod bearings, pistons and valve train. This oil is controlled from...
1997 Toyota Corolla Oil Leak
1997 Toyota Corolla 4 Cyl Automatic 75,000 Miles I Was Driving And I Ran Over A Brick Or Something In The Rain. The Car Went Over It. I...
Asked by
officialkat2006
1997
TOYOTA COROLLA
1997 Toyota Corolla Oil Leaking Alittle
Hi There, It Seems I Have Had To Put Power Steering Fluid In, In The Past 2 And Half Months, Just Filling It Up With...
Asked by
Bridget Patton
1 ANSWER
1997
TOYOTA COROLLA
1999 Toyota Corolla Engine Oil Leakage
Engine Mechanical Problem 1999 Toyota Corolla 4 Cyl Two Wheel Drive Manual 196k Miles Hello, My Question Is My Engine Oil Is...
Asked by
gowthey
1999
TOYOTA COROLLA
Engine Oil Leakage
The Car Has A 1.6l 4af Engine. The Engine Has Been Overhauled 7 Months Ago. After Overhaul, These Are The Problems That Arise 1. Engine...
Asked by
Pathmaprasad
1989
TOYOTA COROLLA
VIEW MORE
SPONSORED LINKS
Crankshaft Main Seal Replacement - Front
Crankshaft Seal Replacement - Rear
Can You Fix a Head Gasket with a Sealer?
Online car repair manuals
