water pump plug?
RICK AMACKER
water is leaking from a small hole on the front of my water pump. I have a 94 camry with over 100k miles. Is the small hole ( smaller than a pencil diameter a plug busted out or something else? The manuals are not enough detailed to mention it.
did you receive the picture?
Sep 5, 2007 at 10:48 AM
  • 75,988 POSTS
[quote:e6a983317a="rick amacker"]water is leaking from a small hole on the front of my water pump. I have a 94 camry with over 100k miles. Is the small hole ( smaller than a pencil diameter a plug busted out or something else? The manuals are not enough detailed to mention it.
did you receive the picture?[/quote:e6a983317a]
Sounds like the weep hole-and water pump is a goner-
Sep 5, 2007 at 11:08 AM
