1994 Toyota Camry Water Pump Change
JAGWAG
I have a 1994 toyota camry w/160,000 miles. Where is the water pump and how difficult is it to change it? How hard is it to change the thermostat?
May 26, 2006 at 1:41 PM
LOSONE
  • 1,616 POSTS
You didn't mention which engine but both 4 and V6, the water pump is driven by the timing belt. At 160K you are way beyone the timing belt life and it has to be replaced also. You should consider a tensioner also as if water drips on it, it is finished. The T-stat is easy but the water pump and timing belt require a good mechanic to do it right.
Good luck
May 27, 2006 at 6:59 AM
Suggested Repair
Replace the timing belt and consider the tensioner when replacing the water pump, since the pump is timing-belt driven and the belt is overdue at 160,000 miles. The thermostat is relatively easy, but the water pump and timing belt should be done by a competent mechanic.
Conversation Summary
The owner of a 1994 Toyota Camry with 160,000 miles asked where the water pump is and how difficult the pump and thermostat are to replace. The expert said both four-cylinder and V6 pumps are driven by the timing belt, which is overdue and should be replaced, and recommended considering the tensioner. The thermostat is easy, but the pump and belt job requires a good mechanic.
