2000 Toyota Camry Timing Belt Water Pump Fix
BFSTAUFF
On routine maintenance of my 2000 camry 4 cyl with less than 90,000 miles, the shop suggested replacing the timing belt as a preventive measure. Shouldn't the water pump also be replaced as a preventive measure when the timing belt is being replaced? Thank you.
Jun 10, 2007 at 4:23 PM
  • 75,988 POSTS
[quote:f2b6baf9de="bfstauff"]On routine maintenance of my 2000 camry 4 cyl with less than 90,000 miles, the shop suggested replacing the timing belt as a preventive measure. Shouldn't the water pump also be replaced as a preventive measure when the timing belt is being replaced? Thank you.[/quote:f2b6baf9de]
I would change both,am in there might as well do it for the love of preventive maintenance.
Jun 10, 2007 at 11:55 PM
Suggested Repair
Replace the timing belt and water pump together as preventive maintenance while the timing cover is already off.
Conversation Summary
The owner of a 2000 Toyota Camry 4-cylinder with under 90,000 miles was advised to replace the timing belt preventively and asked whether the water pump should be done at the same time. The expert recommended replacing both while the job is open.
