After this it would turn over but not start. I changed the fuel pump and filter, checked the plugs and wires. It started again, but with the same symptoms. There isn't any gas in the oil for now.
I have looked for cracked or torn vacuum and fuel lines. I unplugged the EGR valve to see if it made a difference. I checked electrical connections and found one of the oxygen sensors had a broken wire. I repaired it and for about 3 to 4 minutes the car ran fine. No high rpms or white smoke. I turned it off to make sure all tools and items were out of the way before I took it for a test drive. When I cranked it back up there was the high rpms and white smoke and fuel coming out of the exhaust. I had a tester put on it and it showed normal, no error codes. No check engine light at any point. I am unsure where to go from here. I was planning on giving the car to my son for college, but not until this is resolved. Any ideas?
Thanks,
Tim
