1994 Toyota Camry Water Pump Leak
RICK AMACKER
water is leaking from a small hole on the front of my water pump. I have a 94 camry with over 100k miles. Is the small hole ( smaller than a pencil diameter a plug busted out or something else? The manuals are not enough detailed to mention it.
did you receive the picture?
Sep 5, 2007 at 10:48 AM
  • 75,988 POSTS
[quote:e6a983317a="rick amacker"]water is leaking from a small hole on the front of my water pump. I have a 94 camry with over 100k miles. Is the small hole ( smaller than a pencil diameter a plug busted out or something else? The manuals are not enough detailed to mention it.
did you receive the picture?[/quote:e6a983317a]
Sounds like the weep hole-and water pump is a goner-
Sep 5, 2007 at 11:08 AM
Suggested Repair
Replace the water pump. The small hole is the weep hole, and leakage there means the pump has failed.
Conversation Summary
The owner of a 1994 Toyota Camry with over 100,000 miles reports water leaking from a small hole on the front of the water pump and asks whether a plug has failed. The expert identifies the hole as the weep hole and says the water pump has failed.
