1996 Toyota Camry AC Water Leak
JENNY GIRL
i have a toyota camry 96...it runs great but the air conditioner leaks on my foot..it leaks enough to cover my back feet area with at least 2 inches of water...so i took the wiper blades off, clean out that area..which had nothing in it....and poured water down that hole....it leaked out exactly where it was soposed to....now what....i don't want to break a nail...so any ideas...
jenny :roll:
Aug 11, 2007 at 2:20 AM
  • 75,988 POSTS
[quote:2b9866d5df="jenny girl"]i have a toyota camry 96...it runs great but the air conditioner leaks on my foot..it leaks enough to cover my back feet area with at least 2 inches of water...so i took the wiper blades off, clean out that area..which had nothing in it....and poured water down that hole....it leaked out exactly where it was soposed to....now what....i don't want to break a nail...so any ideas...
jenny :roll:[/quote:2b9866d5df]
Check your condensation tube could be clogged-up, do u see antifreeze with that water?
Aug 11, 2007 at 9:24 AM
Suggested Repair
Check the AC condensation drain tube for a clog. Also confirm the fluid is plain water and not antifreeze, which would point to a heater-core leak.
Conversation Summary
The owner of a 1996 Toyota Camry reports the air conditioner leaking enough water to cover the rear footwell. They cleaned the cowl area under the wiper blades and confirmed water poured into that drain exits where expected. The expert advises checking whether the condensation drain tube is clogged and whether the fluid contains antifreeze.
