[quote:3406e5ea99="willcvl"]Make: Toyota
Model: Camry
Year: 1995
Milage: 120K
Engine size: 2.2 liter
The auto transmission won't shift into overdrive when cold. Is this normal? Someone told me the Transmission Fluid Temperature sensor does not allow overdrive when the transmission fluid is too cold. Why?[/quote:3406e5ea99]
I will try the coolant temperature sensor. It prevents overdive and lock-up under predetermined temperature 122deg-162deg
The computer monitors coolant temperature and sends the signal to the OD1 ECT ECU. The ECU will provide OD and Lock-up when the temperature has reach its calibration point.
Could be the throttle position and vehicle speed sensors,these sensors controls throttle and governor pressure.
Jun 10, 2007 at 11:09 AM
