2004 Toyota Camry Gear Indicator Light
CGRMAC
I have a 2004 Toyota Camry SE 4 cyl auto. The gear indicator on the consol has a area that appears to be back lit. It however does not light up. I can't remember if it ever did. Do you know if Toyota made this indicator back lit? If so, how do I get it apart to check the bulb?
Thanks
Jul 13, 2007 at 12:49 PM
  • 31,937 POSTS
Hi there,
Yes there is a globe there, it is a simple jobe to replace, you have to remove the top off the console, & un do 4 screws that holsd the slider & the globe is accessed under the gear indicator, you may find it a bit tricky getting every thing back into alignment, so if in doubt about doing it, your mechanic should be able to replace it in about 15Min
Good luck
Mark (mhpautos)
Jul 19, 2007 at 11:26 AM
Suggested Repair
Replace the gear-indicator bulb. Remove the console top, undo the four screws holding the slider, and access the bulb under the gear indicator. Reassembly alignment can be tricky; a mechanic can typically do the job in about 15 minutes.
Conversation Summary
The owner of a 2004 Toyota Camry SE asked whether the console gear indicator is backlit and how to reach the bulb because it does not light. The expert confirmed there is a bulb and said to remove the console top and four slider screws to access it under the indicator, noting that getting parts realigned can be tricky.
