2003 Toyota Camry Transmission Flush
STICKGLC
Hello, I Have a 2003 camry lte. It has 53000 mainly highway miles on it. I had the oil change recently and the tech told me that I need to have the transmisson flushed and fluid changed. I have been getting conflicting stories as whether to do it or not. Can you give me any guidance as to perform this service or not.
Thanks
May 7, 2007 at 9:35 AM
  • 75,988 POSTS
[quote:20bcee2b81="stickglc"]Hello, I Have a 2003 camry lte. It has 53000 mainly highway miles on it. I had the oil change recently and the tech told me that I need to have the transmisson flushed and fluid changed. I have been getting conflicting stories as whether to do it or not. Can you give me any guidance as to perform this service or not.
Thanks[/quote:20bcee2b81]
Its a good preventive maintenance for the tranny
May 7, 2007 at 11:01 AM
DESERTROSE
  • 12 POSTS
So Have you changed the Transmission Oil because i am also having the same miles and tech guy was telling me to change the tranny oil.
Let me know how it went on your side?
Thanks
May 31, 2007 at 8:49 AM
Suggested Repair
Have the transmission fluid changed or flushed as preventive maintenance, as recommended for this mileage.
Conversation Summary
The owner of a 2003 Toyota Camry with about 53,000 mostly highway miles asked whether to follow a shop recommendation to flush and change the transmission fluid after receiving conflicting advice. An expert said the service is good preventive maintenance for the transmission. A later user with similar mileage asked about the outcome, but no result was reported.
