Toyota Camry P0773 Shift Solenoid
PILLSBURY
  • 9 POSTS
my camry has 78000 miles on it, and i recently got a transmission trouble code. CODE P0773 but the check engine light went out. the car drives fine. will i be ok if just LEAVE IT ALONE?
Feb 28, 2007 at 4:56 PM
LOSONE
  • 1,616 POSTS
PO773 is a shift solonoid code. If the tranny is shifing OK leave it alone. At 78K I suggest you servcie the transmission and add some Slick 50 additive. The solonoids are not serviced but replaced. Give the change a try.
Let me know losone
Mar 3, 2007 at 4:01 AM
PILLSBURY
  • 9 POSTS
[quote:86ca469f70="losone"]PO773 is a shift solonoid code. If the tranny is shifing OK leave it alone. At 78K I suggest you servcie the transmission and add some Slick 50 additive. The solonoids are not serviced but replaced. Give the change a try.
Let me know losone[/quote:86ca469f70]
Hi. At 58K miles i replaced the tranny fluid (with mobil-1 full synthetic). when a check engine light comes on, is there a set time for it to go off? or does it quict when it doesn't sense the problem anymore. thats why i asked if i should leave it. i love my camry, so if i notice anything different about the shifting, then i will get it replaced. i still feel fortunate, compared to all the problems that my brother has had with his chevy. thanks for your time guys!
Mar 3, 2007 at 12:07 PM
Suggested Repair
If the transmission still shifts normally, the P0773 shift-solenoid code can be monitored. Service the transmission fluid and consider an additive; replace the solenoid if shifting problems return, since solenoids are replaced rather than serviced.
Conversation Summary
A Toyota Camry owner with 78,000 miles reported code P0773, but the check-engine light went out and the car drove normally. The expert identified it as a shift-solenoid code and said it could be left alone if shifting remained normal, while recommending a transmission service and additive. The owner had already changed the fluid at 58,000 miles and planned to replace the solenoid only if shifting changed.
