2005 Toyota Camry Check Engine Light
NCK12NICHOLSPD
I drive a 2005 Toyota Camry, it has 48,000 miles on it. Every 5,000 miles the service (check engine) light comes on, just because that's the way my car was made. The guys at the shop were always able to turn it off for me by doing something with the ignition--do you know how I can get it to go off? I would love to not have to take it back in just for that. Thanks for your time!
Jan 2, 2007 at 12:14 PM
  • 75,988 POSTS
Just remove the EFI fuse for 10sec or better-bear in mind that a malfunction exist and its being detected by the ECU-need to have the OBD2 pull for codes to resolve the light problem.
Jan 2, 2007 at 12:34 PM
Suggested Repair
Remove the EFI fuse for about 10 seconds to reset the light, but have an OBD2 scan performed to pull codes because the ECU is detecting a malfunction.
Conversation Summary
The owner of a 2005 Toyota Camry with 48,000 miles says the check engine light comes on every 5,000 miles and shops have cleared it using the ignition. The expert says the EFI fuse can be removed for 10 seconds, but a malfunction is being detected and an OBD2 code scan is needed to resolve the light.
