Engine check light
BOBK544
I replaced the front Oxygen Sensor on my 1999 Toyota Camry and the "Engine Check Light" is still on even after pulling the battery connections!
Do i have to do anything special with the Camry to turn that light off?
I'm hoping that the original problem has been fixed and that the light only needs to be reset?
Thanks for any insights!
BobK
Fairfax Va
Sep 9, 2006 at 5:30 AM
  • 75,988 POSTS
Try removing the EFI fuse for 10sec or more, if it comes back. Jump T1 to E! on the diagnostic connector, then start counting the flash of the lite.
Sep 12, 2006 at 9:27 PM
