1991 camry wont shift out of 1st?
EIYSE98LS1
1991 camry 4cyl. auto trans. 242000miles
what can be the cause of a no shift condtion? manual shifting still has no effect. trans stays in 1st n matter what you do.. what should i do 1st?
thanks
Feb 27, 2007 at 3:37 PM
RPRYOR
  • 8 POSTS
Have you checked your trans fluid levels? When waws it changed last?
I found that mine sticks in shifting when the fluid got low or was real old. Just a thought.
Feb 28, 2007 at 1:04 AM
  • 75,988 POSTS
[quote:c31a8fc08f="eiyse98ls1"]1991 camry 4cyl. auto trans. 242000miles
thanks[/quote:c31a8fc08f]
Have these check: ECT/TPS/VSS sensors they are part of the transmission operation to include the shift solenoids in the tranny.
Do a fluid and filter change and see what happens
Feb 28, 2007 at 4:23 AM
EIYSE98LS1
[quote:6e5a50ab86="rasmataz"][quote:6e5a50ab86="eiyse98ls1"]1991 camry 4cyl. auto trans. 242000miles
thanks[/quote:6e5a50ab86]
Do a fluid and filter change and see what happens[/quote:6e5a50ab86]
where is the vss and ect located? wouldnt the vss be near the cv axle (outer part) with a wire to sense pulse? the ect is be on the block some where 2 wire?
thanks
Feb 28, 2007 at 2:51 PM
  • 75,988 POSTS
[quote:c08070cfc2="eiyse98ls1"][quote:c08070cfc2="rasmataz"][quote:c08070cfc2="eiyse98ls1"]1991 camry 4cyl. auto trans. 242000miles
thanks[/quote:c08070cfc2]
Do a fluid and filter change and see what happens[/quote:c08070cfc2]
The VSS is at the tranny and ECT engine coolant temperature is somewhere near the thermostat housing
Mar 1, 2007 at 5:36 AM
