1993 Toyota Camry Antifreeze Leak
KELLS
My car is leaking antifreeze into the car underneath the carpet. I had my heater core replaced, but it only stopped for a few months and now it is doing it again. Could it be the water pump? it is a 1993 Toyota Camry 6 cylinder with over 150,000 miles.
Feb 27, 2007 at 9:44 PM
SERVICE WRITER
  • 9,123 POSTS
Who ever replaced the heater core needs to re-check their work. Not too likely it is anything other than the heater core or the hose connections to it.
Feb 27, 2007 at 10:12 PM
Suggested Repair
Have the heater core replacement rechecked, including the heater core and the hose connections to it. A water pump is unlikely to cause coolant under the carpet.
Conversation Summary
The owner of a 1993 Toyota Camry reported antifreeze leaking under the carpet. The heater core had been replaced, but the leak returned after a few months, and the owner asked whether the water pump could be responsible. The expert said the installer should recheck the work and that the leak is most likely from the heater core or its hose connections.
