1999 Toyota Camry Coolant Leak
SEANT
1999 Toyota Camry LE 116,000 miles 4cyl: I am leaking engine coolant but when I took the car to our mechanic he was unable to locate any leak. However, the car makes a "slurping sound" like the coolant is being sucked into the engine while I'm driving. Also, the heater in the car works sporatically and when it is on sometimes you can smell the coolant. There is no noticeable leaks but it needs a refill almost everyday. If you have any ideas on what the problem could be that would help. Also, 3 years ago replaced the head gasket, water pump and timing belt if this makes any difference.
Apr 17, 2007 at 11:26 AM
  • 75,988 POSTS
[quote:e95ad70c44="seant"]1999 Toyota Camry LE 116,000 miles 4cyl: I am leaking engine coolant but when I took the car to our mechanic he was unable to locate any leak. However, the car makes a "slurping sound" like the coolant is being sucked into the engine while I'm driving. Also, the heater in the car works sporatically and when it is on sometimes you can smell the coolant. There is no noticeable leaks but it needs a refill almost everyday. If you have any ideas on what the problem could be that would help. Also, 3 years ago replaced the head gasket, water pump and timing belt if this makes any difference.[/quote:e95ad70c44]
Coolant smell in vehicle its an indication of the heater core is leaking.
Try refilling it, run the engine and bleed the air out
Apr 17, 2007 at 2:49 PM
Suggested Repair
Inspect the heater core for an internal leak indicated by the coolant smell and intermittent heat. Refill the cooling system, run the engine, and bleed out trapped air.
Conversation Summary
A 1999 Toyota Camry loses coolant almost daily with no visible external leak, a slurping sound while driving, intermittent heater operation, and a coolant smell when the heater is on. The head gasket, water pump, and timing belt were replaced three years earlier. The expert said the coolant smell indicates a leaking heater core and advised refilling the system, running the engine, and bleeding the air.
