My girlfriends 1994 toyota camry 4 cylinder is leaking antifreeze. Its leaking from the back of the water pump where there are two metal pipes running to the engine, nothign appears cracked I am wondering if there is a gasket that joins the water pump and thoes tubes or if I need to replace the whole water pump
SPONSORED LINKS
Thursday, January 14th, 2010 AT 4:30 PM
