Take it to a mechanic you trust, he should be able to tell you fairly quickly where the oil leak is. The antifreeze leak may need to be pressure tested, but that's not usually too much money. If you're positive its antifreeze and not transmission fluid. They are similar in color on this car.
SPONSORED LINKS
Friday, October 23rd, 2009 AT 2:44 AM
