1996 Toyota Camry No Speaker Sound
TONY1958
1996 Toyota Camry LE 139,000 4 cylinder. My sound system speakers have gone out. Radio still comes on, tape player was busted when I bought it two years ago, just no sound from the speakers. Blown fuse? If so what's the fuse location? No owners manual. Thank you in advance.
Aug 19, 2007 at 11:43 AM
  • 75,988 POSTS
[quote:75632f6a08="Tony1958"]1996 Toyota Camry LE 139,000 4 cylinder. My sound system speakers have gone out. Radio still comes on, tape player was busted when I bought it two years ago, just no sound from the speakers. Blown fuse? If so what's the fuse location? No owners manual. Thank you in advance.[/quote:75632f6a08]
If the fuse is blown I don't think it will come On. Go behind it and double check the connectors
And BTW if your built-in Amplifier is a goner-You'll never hear sounds. That's where the speakers are hook-up. Trust me I use to do Stereo Installations
Or could be another fuse power the amp-check all the fuses you can find.
Good Luck
Aug 19, 2007 at 12:01 PM
Suggested Repair
Check the connectors behind the radio. A blown radio fuse is unlikely if the radio still powers on. Inspect all fuses, including any that power the built-in amplifier, and test the amplifier because the speakers connect through it.
Conversation Summary
The owner of a 1996 Toyota Camry says the radio powers on but there is no sound from the speakers; the tape player was already broken. The expert says a blown radio fuse would likely keep the radio from turning on, so the connectors behind the radio, all fuses that may power the amplifier, and the built-in amplifier should be checked.
