Hi my doom light doesn't work, I've replaced the bulb many times but no luck. It works once in a blue moon but that's all!
Mar 31, 2006 at 5:49 AM
Confirm the bulb seats tightly; if loose, gently squeeze the empty socket and reinstall the bulb. With the switch on, jump a known ground to the outside of the socket. If the light then works, the fault is the ground path or switch (door switches supply ground). Power and ground for this circuit come from Junction Box number one.
A 1994 Toyota Camry dome light behind the sunroof rarely works despite repeated bulb replacements. The expert explained it is a simple 12-volt circuit that is grounded through the switch or door switches, and advised checking socket fit, testing the socket ground, and tracing power and ground to Junction Box number one.
