Clutch
VRIVAS1126
  • TOYOTA CAMRY
Hi I have a Toyota Camary 1992 aprox. 190,000 miles and a V6 manual car. I have been having problems with the clutch. When I push down on the clutch it stays on the floor, I can bring it back up but will not shift gears. It also is very loose. When I opened the hood to take a look at it and pushed on the clutch you can hear and see fluid coming out. So I am guessing that I have a Hydraulic clutch and that it has a leak. Do you think that I just need a new line/pump for the clutch or do you think it's going to take way more than that?
Tuesday, November 27th, 2007 AT 6:42 PM
  • 31,937 POSTS
Hi there,
If the slave cylinder is leaking at the gear box, this will need to be replace (simple job) but the hydraulic system will need to be bleed of air. If you want more details re post and I will advise.
Mark (mhpautos)
Tuesday, November 27th, 2007 AT 7:00 PM
