1992 Toyota Camry clutch shake?
DNB
  • 1992 TOYOTA CAMRY
  • 4 CYL
  • MANUAL
  • 308,000 MILES
Hi guys, when I start off in first gear, the engine shakes and bangs real bad, but while driving seams ok. THANKS LADS.
Monday, February 2nd, 2009 AT 4:44 PM
  • 31,937 POSTS
Hi there,
This is called clutch shudder and is a sign of clutch wear and hot spots on the fly wheel, as the clutch is taking up it is slipping a little and causing this vibration, you will need a full clutch o/haul and a flywheel machine to fix this problem.
Mark (mhpautos)
Monday, February 2nd, 2009 AT 5:19 PM
