2000 Toyota Camry Erratic Climate Control
LARRYO
I am asking about a 2000 Camry, with 63000 miles on it. The 'Automatic' climate control panel in my 2000 Camry is erratic. Can I replace it with a manual one? If so, what's the best way to remove the plastic trim around the panel?
Thanks for any help.
Mar 30, 2006 at 7:47 AM
LOSONE
  • 1,616 POSTS
Almost impossible to replace an auto with a manual. The bezel has plastic clips. use a small hook tool to free it. There might be a screw or two under the lip.
Check your temp sensors before you replace the auto module. If there have been smokers in the car they have a tendencey to clog from nicotine. They also clog with normal dust. Check them 1st. Good Luck.
Mar 30, 2006 at 9:32 AM
LARRYO
2000 Camry - 63000 miles.
Thanks to losone for the quick reply. Can you tell me where the A/C Temp Sensors are located?
Mar 31, 2006 at 5:22 AM
LOSONE
  • 1,616 POSTS
They are behind a small grill about the size of a 25c piece on the dash. Somestimes they one by the windshield
Mar 31, 2006 at 6:08 AM
Suggested Repair
Do not swap the automatic climate control for a manual unit; it is nearly impossible. Before replacing the automatic module, check the temperature sensors, which sit behind a small quarter-sized grill on the dash and sometimes near the windshield. Dust or nicotine residue can clog them. If the bezel must come off, release its plastic clips with a small hook tool and check for one or two screws under the lip.
Conversation Summary
Owner of a 2000 Toyota Camry with 63,000 miles reports an erratic automatic climate control panel and asks whether a manual panel can be fitted and how to remove the surrounding trim. Expert says an auto-to-manual swap is almost impossible, describes freeing the bezel clips with a small hook tool and possible screws under the lip, and advises checking the dash temperature sensors first because dust or nicotine can clog them. Sensors are behind a small grill about the size of a quarter on the dash, sometimes near the windshield.
