1999 Toyota Camry Cruise Control Blinks
RBJ967
I RECENTLY PURCHASED A 1999 TOYOTA CAMRY WITH 75000 MILES ON IT. THE CRUISE CONTROL DOES NOT SEEM TO BE WORKING. WHEN I PUSH THE BUTTON TO TURN IT ON, THE "CRUISE" LIGHT WILL COME ON, BUT WHEN I PUSH UP ON THE SWITCH TO ENGAGE IT , THE "CRUISE" LIGHT STARTS TO BLINK OFF AND ON AND THE CRUISE DOES NOT COME ON. CAN YOU HELP ME
THANKS
RBJ967
Dec 28, 2006 at 4:02 AM
  • 75,988 POSTS
These are the system components of the C/C
1.Vehicle Speed Senssor
2.cruise control module
3.Actuator
4.Brake Switch
5.Clutch Switch if Manual Tranny same as the brake switch operation
6.Throttle Linkage
Does your Speedometer Works? -if not it won't hurt to check the VSS if its the VSS it will not give the Brain (Cruise Control Module) the speed signal or when the CCM goes bad either it will not understand the signal from the VSS or unable to send the signal to the actuator.
If its not an obvious problem like disconnected harness, broken wire,blown fuse and leaking vacuum hose then most likely its the CCM or it switches that sets the speed and contains other functional areas such as the resume and accelerate.
Check the vacuum diaphragm inside the actuator for leak this problem will cause it not to properly operate or it will not set at all. Also the linkage for disconnection or broken chain bead
BTW the Actuator works the same way as the Brake booster one pulls the accelerator the other gives your foot a rest.
Good Luck! This is the best I can give, not there to see what's happening
Happy New Year 2007
Dec 28, 2006 at 8:43 PM
Suggested Repair
Verify the speedometer works, then inspect the vehicle speed sensor, cruise control module, brake switch (and clutch switch if manual), throttle linkage, wiring, fuses, and the actuator vacuum diaphragm and linkage for leaks or disconnection.
Conversation Summary
A 1999 Toyota Camry owner reports that the cruise light comes on, but engaging cruise makes the light blink and the system will not set. The expert lists the speed sensor, cruise module, actuator, brake and clutch switches, and throttle linkage as key components, and recommends checking obvious wiring, fuse, vacuum hose, diaphragm, and linkage faults before suspecting the module or control switches.
