This is a 1995, but I believe it is a 94, manufactured at the beginning of the 95 model year. A few days ago my cruise control light blinked a few times. The next time I started it, the problem stopped. Then the check engine light came on intermittently. I did not have a chance to get the codes checked, and I believe I lost them. A few days later, while driving under cruise control, the control disengaged, and simultaneously, the speedometer, tachometer, odometer, temperature guage, power windows, A/C, ventilation fans, and all dashboard lights (except airbag) stopped working. I could not find any blown fuses, but I probably did not find all the fuse blocks. Can you help me with a diagnosis?
I should add that the transmission seems to shift only from first to second, and the battery is dead, so the alternator is probably not working.
May 7, 2009 at 12:15 AM
