Cruise control will not turn on
150,000 MILES • 2.3L • 4 CYL • FWD • AUTOMATIC
WHITTER
  • 5 POSTS
When I push the cruise control on/off button to turn on the cruise control, it doesn't work. If I push it multiple times, quickly, it does turn on occasionally. I believe it is a bad on/off switch and needs to be replaced. What is the procedure for replacing the on/off switch at the end of the cruise control arm in this car?
Thanks,
Bob
Mar 17, 2015 at 6:00 AM
  • 110,248 POSTS
Bob:
I'm trying to remember the 01. Is the button part of the multi-function switch?
Mar 17, 2015 at 11:12 AM
WHITTER
  • 5 POSTS
It is a push button on the end of the cruise control arm coming off of the steering wheel its only for the cruise control
Mar 17, 2015 at 11:42 PM
  • 110,248 POSTS
Most likely, it's the switch then.
Mar 19, 2015 at 1:44 AM
