Fuel filter
  • 31,937 POSTS
You can often get a free code read from major auto retail stores, they will not do a fuel rail pressure test.
Wednesday, December 4th, 2019 AT 5:46 PM (Merged)
98TOYOTA
  • 1998 TOYOTA CAMRY
Engine Performance problem
1998 Toyota Camry 4 cyl 151000 miles
I'm trying to replace the fuel filter but i'm having problems with the lower connection of the old filter. It's rusted on really bad and if I end up twisting off and tearing the fuel line at the connection what can I do quickly to fix it?
Thanks
  • 31,937 POSTS
Hi there,
These are one of the hardest filters to change. What I do is remove the top fitting, and unbolt the bracket off the inner guard. Carefully twist the filter & pipe down enough to see the union nut. There is a fair amount of give but be carefully, then using a good quality 14mm pipe spanner and also using a spanner to hold the filter, you should be able to easily undo the fitting, bay be give it a good spray and let it sit for a bit first.
Mark (mhpautos)
PATRICK GILLAN
  • 1998 TOYOTA CAMRY
1998 Toyota Camry 4 cyl Front Wheel Drive Automatic 156K miles
iwas told that my fuel filter is LIFETIME and I do not need to replace it. Do you agree? The car is running great!
BLUELIGHTNIN6
  • 16,542 POSTS
That is correct. There is no service interval for your vehicle's fuel filter. It is supposed to last the life of the vehicle.
TAMBO1022
  • 1998 TOYOTA CAMRY
  • 4 CYL
  • 125,000 MILES
1998 toyota fuel filter is leaking gas
Wednesday, December 4th, 2019 AT 5:47 PM (Merged)
Wait for it to stop leaking and inspect where its leaking and remove and replace
Let me know the status-this is a fire hazard
