99 camry gas smell?
RY605
I have 99 camry 4cyl. It has 78k and has had all the
service always done on time. Lately it seems to have
a fairly strong gas smell, but it is not constant. I have driven with ac on/off and the smell just seems to come and go. I have no clue what is causing this.
Any help would be awesome. Thanks
Jul 2, 2007 at 8:26 AM
LMCCANN
[quote:93f5b4b368="ry605"]I have 99 camry 4cyl. It has 78k and has had all the
Any help would be awesome. Thanks[/quote:93f5b4b368]
I was just wondering if you found out what was causing the smell. My 2002 Camry has the same problem.
Aug 24, 2007 at 5:19 AM
RY605
I haven't figured out the problem but when the gas
is under a 1/8 tank it gets much stronger. Its noticeable inside but outside it is quite strong. I am hoping to this weekend drop the tank and see if there are any leaks in the system -
Aug 24, 2007 at 6:01 AM
FROMTAZ
[quote:04e4151fda="ry605"]I haven't figured out the problem but when the gas
is under a 1/8 tank it gets much stronger. Its noticeable inside but outside it is quite strong. I am hoping to this weekend drop the tank and see if there are any leaks in the system -[/quote:04e4151fda]
I have a '07 Camry Hybrid and I just has my car in to the dealer for the same problem this morning. First they thought I was crazy for smelling fuel inside the car. They claimed that they checked all of the hoses and they found nothing. The smell comes and goes in my car and there seems to be no connection between amount of gas in the tank, temp outside, how long i have been driving... They keep telling me that if there was any issue with the car the check engine light would have come on.
Please let me know if you get your issue resolved so I have something to go back to the dealer with.
Aug 27, 2007 at 5:10 AM
