HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Toyota
Camry
Engine
Symptoms
Oil Leak
1998 Toyota Camry losing oil
LETTI28
MEMBER
1998 TOYOTA CAMRY
4 CYL
FWD
AUTOMATIC
200,000 MILES
My car is losing oil and there is no leaks. The oil is going to the radiator. What is the problem.
Sunday, June 22nd, 2008 AT 4:58 PM
KHLOW2008
MECHANIC
Hi letti28,
Sorry to say that you engine has a serious problem with the following possibilities.
1. A blown head gasket.
2. A cracked cylinder head or engine block.
3. A cracked oil cooler if any is installed.
SPONSORED LINKS
Monday, June 23rd, 2008 AT 12:20 PM
Please
login
or
register
to post a reply.
Related Engine Oil Leak Content
1998 Toyota Camry Oil Leak
We Have An Oil Leak At A "fitting" On The Front Of The Engine, Passenger Side Just Below The Head Gasket. The Oil Just Squirts Out At The...
Asked by
owen0118
1998
TOYOTA CAMRY
GUIDE
Engine Oil Leak
A car engine uses motor oil to lubricate the internal moving parts of the engine such as crankshaft, rod bearings, pistons and valve train. This oil is controlled from...
I Have Oil Coming From Behind What Appears To Be The Timing Chain Cover, What Do You Think Cause Is?Can A Clogged Pcv Valve Cause An Oil...
Asked by
russreo
1998
TOYOTA CAMRY
1998 Toyota Camry Oil Leak From Somewhere Near Engine
Hi Thakns For Providing Such Forum Which Can Help Us. My Camry Has Some Problem With Oil Leak. I Dnt Know Where Exactly From But I Am...
Asked by
ajitsinh
1998
TOYOTA CAMRY
1998 Toyota Camry Oil Leak - 98 Camry - Frontmen...
I've Been Told The Source Of My Oil Leak Is The Frontmen Gasket Which Has Or Could Affect My Timing Belt. What Type Of Leak Is This...
Asked by
minicat
1998
TOYOTA CAMRY
1998 Toyota Camry Oil Leaking
Engine Mechanical Problem 1998 Toyota Camry 4 Cyl Front Wheel Drive Automatic Oil Seeping From Valve Cover Gasket
Asked by
chrissta22
1 ANSWER
1998
TOYOTA CAMRY
VIEW MORE
SPONSORED LINKS
Crankshaft Main Seal Replacement - Front
Crankshaft Seal Replacement - Rear
Cylinder Head Gasket Blown Symptoms
Online car repair manuals
