I've been told the source of my oil leak is the frontmen gasket which has or could affect my timing belt.
What type of leak is this frontmen and if the timing belt is affected, can you WAG a repair cost?
thanks
Monday, May 19th, 2008 AT 10:05 PM
MECHANIC
Hi there,
you better go check what you need as this is not a name of any part on a camry engine, get the part name and re post.
Mark (mhpautos)
SPONSORED LINKS
Tuesday, May 20th, 2008 AT 4:46 AM
BMRFIXIT
MECHANIC
Whats common is the oil pump and seal
they leak at the front by the timing belt area
expect to pay someone about 400 to $500
timing belt should be changed too
