Hi there,
Dose this fitting have one wire attached? If so it's the oil pressure switch, this will easily unscrew with a socket (remove wire first ) If not the pressure switch, there is also the oil filter located near that front of engine position you refer to, this will also "spin of"and is easily replaced. Check these items first. And if not these contact me via I.M. Mark (mhpautos)
SPONSORED LINKS
Saturday, May 10th, 2008 AT 1:00 AM
