1998 Toyota Camry OIL LEAKING
CHRISSTA22
  • 1998 TOYOTA CAMRY
Engine Mechanical problem
1998 Toyota Camry 4 cyl Front Wheel Drive Automatic
OIL SEEPING FROM VALVE COVER GASKET
Friday, July 18th, 2008 AT 6:00 PM
  • 31,937 POSTS
HI there,
This is an easy job to do, just remove the spark plug leads and you will see 4 large nuts try nipping then down or just remove the nuts and lift the rocker cover and replace the gasket.
Mark (mhpautos)
Friday, July 18th, 2008 AT 6:10 PM
