Hello. I have a 1994 Toyota Camry 2-door with 4-cylinder engine and automatic transmission. I am experiencing some sort of electrical problem, I'm pretty sure, but I don't know what it is I need to get fixed. What happens is when you put the car in reverse, the two white backup lights do not always come on. Also, when the backup lights do not come on, the orange "R" (showing what gear you are in) on the dashboard does not come on. It seems, however, that when you jiggle the gear shift handle, it sort of "helps" the lights come on. Also, when you put the car in other gears, the lights on the dashboard do not always come on (and the lights are NOT burned out); again, however, jiggling the handle makes them come on and they sort of "flicker" sometimes when they first come on. If I could get an answer to what this problem is or if I need to clarify any further details, please let me know. Thanks.
Sunday, November 4th, 2018 AT 12:50 PM
(Merged)
