1998 Toyota Camry replacing Back-up lights
W0949829
Electrical problem
1998 Toyota Camry 6 cyl Front Wheel Drive Automatic
I have looked in the trunk and was wondering how to access the the lighting unit to replace the back-up light bulbs
May 22, 2010 at 10:44 AM
BLUELIGHTNIN6
  • 16,542 POSTS
are you certain the bulbs are bad? may first check fuses and the back-up light switch located on tranny
May 23, 2010 at 5:40 AM
W0949829
The dash board indicator says the bulbs are out. but the fuses were the first thing i checked
May 23, 2010 at 11:48 AM
BLUELIGHTNIN6
  • 16,542 POSTS
From the outside of the vehicle, remove the screws retaining the lamp housing to the body. Remove the access cover in the luggage compartment. Disconnect the wiring from the back of the lamp. To replace the bulb, push in and rotate. Inspect the bulb and replace if necessary.
https://images.2carpros.com/forum/automotive_pictures/261618_1_173.jpg
To install: Position the lens to the body of the vehicle and secure with the screws. Attach the wiring to the back of the lamp. Install the access cover and secure.
May 23, 2010 at 1:12 PM
