1998 Toyota Camry cruise control backup lights
67,000 MILES • 4 CYL • 2WD • AUTOMATIC
MIKE MAXEY
backup lights and cruise went out at the same time. The one part that they may have in common is the neutral saftey switch. Is there any other part that they have in common. Do you have any other sugestions?
Aug 29, 2010 at 5:13 AM
BLUELIGHTNIN6
  • 16,542 POSTS
back-up light switch is most likely at fault, it is on the transaxle.
Aug 29, 2010 at 5:14 AM
MIKE MAXEY
This car has and auto trans. no back up switch.
Aug 30, 2010 at 2:14 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if it's automatic than it uses the park/neutral position (PNP) switch which will also be on the transaxle. that is most likely fault since CC went out with them as well.
Aug 30, 2010 at 9:01 AM
MIKE MAXEY
Thanks for the help. Putting switch on tomorrow. Will let you know if it works.
Aug 31, 2010 at 4:11 AM
