I have a 1990 Toyota Camry with 270,000 miles on it. It does not want to start when it's cold outside. But, it does crank and attempt to start. Usually the second time I try to start it, it will start right up. I know I have a part on the car that I can tell is broken, and I think it is the problem. But, my problem is that I have no idea what the part is called; therefore, I can't replace it. It is located in the same housing as the coolant temperature sensor, and it is located just below it on my car. I believe it may be the part responsible for relaying information to the cold start injector, but I'm not sure. It looks like a sensor of some sort, and it looks very similar to the coolant temperature sensor. I noticed that it was broken months ago, but it wasn't affecting the car's operation at that time. Could you tell me what this part is called and what else the problem could possibly be in case its replacement won't fix the problem?
Dec 5, 2006 at 11:43 AM
