1998 Toyota Avalon No Drive When Warm
BENZENO
i recently purchased a 98 toyota avalon the engine was replaced and the car hasnt moved since what it does when its cold u can feel the trans engage but doesnt drive to good like a weak engagement and 2-3 min later it starts to warm up an u get nothin no feel of engagement nothin my question is where do i start diagnosis or do i just go replace or rebuild trans
Jun 8, 2007 at 11:56 AM
  • 75,988 POSTS
[quote:23154f35ea="benzeno"]i recently purchased a 98 toyota avalon the engine was replaced and the car hasnt moved since what it does when its cold u can feel the trans engage but doesnt drive to good like a weak engagement and 2-3 min later it starts to warm up an u get nothin no feel of engagement nothin my question is where do i start diagnosis or do i just go replace or rebuild trans[/quote:23154f35ea]
Could be the vehicle speed sensor,throttle position, and shift position sensor on the neutral safety switch.
Check the above before you go to the shifting solenoids/torque converter lock-up.
Jun 8, 2007 at 6:15 PM
Suggested Repair
Before replacing or rebuilding the transmission, check the vehicle speed sensor, throttle position sensor, and the shift position sensor on the neutral safety switch. Only then consider the shift solenoids and torque converter lock-up.
Conversation Summary
The owner of a 1998 Toyota Avalon says the engine was replaced and the car has not moved since. When cold, the transmission engages weakly; after warming for two to three minutes, engagement disappears. The expert recommends checking the vehicle speed sensor, throttle position sensor, and shift position sensor on the neutral safety switch before the shift solenoids or torque converter lock-up.
